Hey guys
Having only used DvdShrink a couple of times, I was wondering how much compession on the main movie you can get away with before you start to notice it? And do you have a point where you think 'this is gonna be awful if I go ahead'?
I ask because with my last movie (an xxx title) I had to fully compess everything before I could get it to fit on a dvd, and I thought it looked awful afterwards.
Cheers
Bedlam
Results 1 to 16 of 16
It all depends on what the movie is. An action movie with lots of high speed movement will look pretty grim with not a lot of compression. Something that has little rapid movement will still look OK with much more. I find that anything lower than 80% gets quite noticable but that only happens occasionally as I always re-author and only keep the main movie.
To many factors to give an absolute. I use Shrink mainly for re-authoring, and DVD Rebuilder with CCE to reencode to size. If it is only a few % then I'll leave it up to shrink, but otherwise . . . . .
But each to their own. We have had posters claim they can't tell the difference between the backup and the original at a 55% shrink.Read my blog here.
Yes, I first try full disc, and if I go below 70%, I reauthor and keep main title only. At times, I've been forced to go as low as 60-65%, but I've found the quality acceptable (=hardly any noticable difference from the original to my eyes) even at this high compression.
But it all comes down to: Source bit rate (if the video is already @ 4000 kbps, 50% shrinking will look awful, but if it's 9000 kbps, 50% might still look very good), and content
/Mats -
Trial and error, my friend ... trial and error.Originally Posted by Bletch
Only YOU can decide at what percentage YOU start to notice it. After all, it is YOUR eyes watching YOUR backups on YOUR TV ...
Any number of factors can contribute to the final quality, including (but not limited to):- bitrate used in the original production of the DVD
- your eyesight
- your viewing device
You really just need to try a few, and see roughly where your threshold sits.If in doubt, Google it. -
The responses you've gotten so far are on the money. As a general rule of thumb, however, I've noticed that going below about 60% of the original filesize with DVDShrink produces some fairly ugly compression artifacts that are readily visible.
You might think about dumping DVDShrink and trying ReJig instead. ReJig in my experience does a better job of compressing video more without generating obvious compression artifacts. Even with ReJig, though, if you find yourself forced to get down below around 50% of the original filesize it's time to either think about splitting the movie into 2 DVDs or using some computer-only encoding format like divx, or just learning to live with compression artifacts if you absoultye positively must have the complete DVD backed up onto a single DVD-R disc.
ReJig and DVDRebuilder make a dynamite combination. -
You can reduce the amount of compression needed by getting rid of things you don't need such as extra sound tracks, other languages and unwanted features. A 5-channel sound track can take several hundred megabytes for example. Better quality video at the expense of keeping only 2-channel stereo is a pretty good tradeoff. If you want the whole magilla, don't shrink it to start with.
Removing extra soundtracks and picture substreams is a good idea but be careful removing the 5.1 soundtrack and leaving the 2 channel one. On the vast majority of commercial DVDs, the 2 channel soundtrack is the directors commentary and not the movie soundtrack. The other thing to bear in mind is that you may not have a 5.1 system at the moment, but if you buy one in the future then you will need it.
Thanks for your input guys, at the moment I'm trying not to use more than 20% compression, sometimes leaving off extras or foreign language tracks.
Going by the genre of the video (X rated), I don't think eyesight is going to be too much of an issue... 8)Originally Posted by jimmalenko
i like the last comment but to be fair - he was only asking a question no matter WHAT the content!
The problem with the majority of xxx titles is that they are videos put onto dvd. They usually are very poor quality to start with.
If you have poor source in, you will have crap out.
so, even if you use the best backup method of DVDRebuilder and CCE, you will still come up against this problem.
XXX usually means - You Have Been Fleeced Sucker! -
All he said was that "I ask because with my last movie (an xxx titleOriginally Posted by garryheather
)..." - he's actually asking about all movies in general, and not just XXX AFAIK. That was just an example of his last movie
... and I answered it much more generally for the 1,000's of other people who will no doubt ask this question in the future.If in doubt, Google it. -
I once asked this question myself. and got the same "you must choose for yourself answer."
That's all you can doWhat We Do In Life, Echoes In Eternity.... -
6 years later and Blue-ray player/HD tv upscaling does a GREAT job advancing and erasing this primitive problem.
I'm from the future, and I won't be back!
And then again, You could always switch to one of the converter compressors that will convert the mpg2 to h264 and get some real compression without much loss to quality.
Tony -
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
Slysoft CloneDVD2 VS Shrink No Compression
By mn072065 in forum DVD RippingReplies: 0Last Post: 14th Nov 2010, 13:21 -
DVD Shrink compression method question
By SCDVD in forum Newbie / General discussionsReplies: 5Last Post: 14th Jan 2009, 12:42 -
compression and DVD Shrink
By snafubaby in forum Authoring (DVD)Replies: 2Last Post: 13th Dec 2007, 01:15 -
DVD Compression/Shrink Software Recommendation?
By Noy2014 in forum DVD RippingReplies: 7Last Post: 13th Jun 2007, 06:12
