I have converted a VOB file to AVI with VirtualDub Mod. I want to import the resulting file into Premiere Pro. But the process just stalls and nothing happens...
what video codec did you use in virtualdubmod? under video->compression.
What sort of avi ? the AVI format is a container format for video and/or audio data formatted in any number of ways. The format is determined by the codec (e.g. DV, Divx, Xvid, Uncompressed etc). Some codecs are more compatible that others in different programs.
What codec did you use for your AVI ?Read my blog here.
Premiere is pretty picky about Divx. I believe there is one version it accepts, the rest it chokes on. I'm surprised it didn't take uncompressed, but them premiere crashing doesn't mean anything other than premiere is crash-prone and unstable.
Read my blog here.
dv avi, try the panasonic dv codec for example
huffyuv -
Dunno why, but I tried all the codecs, including the ones you mentionned... it doesnt work. I just noticed, that the resulting AVI doesnt playback right (jerking + loses sound after 1-2 secs)
Premiere Pro 1.5 cannot import DivX AVI
By Arjun_M in forum EditingReplies: 6Last Post: 10th Jun 2009, 10:00 -
.MOD to AVI - video converts, but audio doesn't
By bball101 in forum ffmpegX general discussionReplies: 1Last Post: 3rd Sep 2008, 13:43 -
Premiere Pro CS3 and TMPGEnc - Can import AVI but video does not show up...
By chadsxe in forum Newbie / General discussionsReplies: 4Last Post: 15th Feb 2008, 14:05 -
Cant import AVI files into Adobe Premiere Pro 1.5 (again)
By Undead Sega in forum EditingReplies: 1Last Post: 13th Oct 2007, 21:35 -
Premiere Pro 1.5 Won't Import Any AVI? Zoiks!
By glowing_zebra in forum DVD RippingReplies: 1Last Post: 7th Jul 2007, 05:28
