Hello everyone
Not sure whether this question should be here or in the DVD to Avi forum but anyway...
So, I have a bunch of videogame and movie trailers that I want to encode to AVI, the source being a promotional DVD sold with a magazine. Of course, my goal is to get an acceptable size/quality ratio, but I also value speed and compatibility.
I've ruled out proprietary formats (Wmv and RV10) and also Divx so that leaves me with either Xvid or the latest X264. Now, I know it's a really " it depends" kind of thing but which one do you think would be better considering the material (fast action, lots of movement and computer graphics for the game trailers)? Also, are there indipensable tweaks to either codec to improve the quality (I don't know much about matrices and other codec settings?) And finally, is there a "threshold" bitrate below which quality degradation really shows? I was once told that 1500 kbps was really the lowest acceptable bitrate but that was in the Divx4 era
Any help will be much appreciated![]()
The first question would be what format the videos are currently stored in and whether they actually require conversion or not. Any of the formats are capable of what you are trying to achieve and the specs of the original files can act as a guide in any conversions that you make. Of course the avi container will create files of the smallest size, expecially using divx/xvid.
Google is your Friend -
Using XviD and avi would give you the advantage of standalone compatibility. With x264 you have already lost that so there is no point in using avi as the container. Go with mp4 or mkv with x264 stored as native AVC.
Thanks for the replies
The videos are currently vob files. I'm probably going to use Xvid, x264 is still too slow on my computer. That being said, I have a few questions about x264:
1) Why is it a bad idea to use x264 with avi?
2) Also, what are the main differences between mp4 and mkv?
3) I use Gordian Knot to encode my videos and it only seems to support MKV; any recommendations for a program able to output mp4 files?
Thanks for the assistance, it's much appreciated.
Codec configuration problem?
By Phantomht in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2011, 12:50 -
Question about codec's
By carl606 in forum Newbie / General discussionsReplies: 6Last Post: 3rd Apr 2010, 09:54 -
AVIDemux 1-pass vs. 2-pass Configuration Question
By robindean in forum Video ConversionReplies: 2Last Post: 12th Mar 2010, 20:32 -
2009 Video Codec Choice
By jason in forum Newbie / General discussionsReplies: 20Last Post: 24th Jun 2009, 14:52 -
Network Configuration Question
By wwaag in forum ComputerReplies: 3Last Post: 31st Mar 2008, 22:56
