I have transferred an old VHS recording to a DVD (using TMPGEnc as encoder and DVD Architect as author). When just played on my Pioneer DV-444 everything works just fine. But if I fast forward, or use search mode to go to a specified time, or use the menu to select a certain chapter, it will play for about 2 seconds then slow down and finally hang.
I have tried the DVD on Centrum Gemini (220 and 340) and there is no problem there. Though there was a problem on a LG RH-7500.
What could have gone wrong here?
What should I do about it?
I have the Pioneer 444, and have had no real problems with DVD-R, DVD+R, and DVD-RW. From the symptoms you describe, it sounds like the machine is having trouble reading the disc, or the MPEG stream isn't DVD compliant.
I would try using a different media, and lowering your burn speed to rule out the former. -
Well this is my first real problem with the 444 (apart from SVCDs on old CD-RWs hanging).
I have tried this movie on many different +R and +RW discs (though addmittedly same brand) and different speeds. I also tried putting it through DVD Shrink.
I have never experienced TMPGEnc producing non-compliant streams before. (Possibly I used some stupid setting?) Is there anyway to test if that is the case? And if so, what could I do about it? -
Well TMPGenc is what I use. I read somewhere to make sure that you have the GOP sequence set correctly, but I have had no problems with any files / discs not working. Maybe try a differnet authoring package with the same source files and see if the problem still exists.
I guess it's just a process of elimination unfortunately. -
The reason seems to have been that the total bitrate of maximum video quality and 2 PCM tracks was too high. When re-encoding audio to AC-3 the problem dissappeared!
Pioneer DV 585a playing several new movies in wrong chapter order.
By snirpens in forum DVD & Blu-ray PlayersReplies: 0Last Post: 14th Apr 2012, 14:52 -
why do some dvds not allow elapsed time/chapter to display?
By spiritgumm in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2011, 11:27 -
Capture hangs forever on both Windows boxes 95% of the time!
By ambushed19 in forum Capturing and VCRReplies: 45Last Post: 18th Apr 2009, 21:17 -
Pioneer DVR-531H-S Time Drift
By srt842 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 6th Mar 2009, 13:05 -
LG LRH-890 vs Pioneer DVR-550 - manual chapter points??
By Hookah_Bon in forum DVD & Blu-ray RecordersReplies: 0Last Post: 31st Jul 2007, 17:55
