my computer which was having 80gb has now 763gb. i check and found out that there are partitions namely extended and unallocated partitions each 7,8 mb. can can i do to mearge all of them.
An 80GB harddrive normally has only about 76GB available. Some computers use a hidden partition for diagnostic uses. This is common on laptops. The unallocated partition may be used for something also.
They are usually in the 8MB range. Deleting them may not be a good idea. Just to gain that small amount of space may make your OS or diagnostic or repair programs inoperable. Was your computer set up when you got it? If so they may be necessary.
HDD Partitions question.
By SE14man in forum Newbie / General discussionsReplies: 13Last Post: 24th May 2011, 14:32 -
FFMPEG -partitions
By Klagar in forum Video ConversionReplies: 0Last Post: 4th Oct 2010, 11:12 -
partitions
By jyeh74 in forum ComputerReplies: 11Last Post: 1st Jul 2009, 22:33 -
Best way to partion a 1TB into 2 partitions using Fat32
By cal_tony in forum ComputerReplies: 6Last Post: 21st May 2009, 12:10 -
Join two partitions
By Jomapil in forum ComputerReplies: 5Last Post: 11th May 2009, 16:28
