Hi, I have a logitech quickcam and wanted to record avi videomail files to send to my friend overseas.
I used the logitech quickcam software and recorded 12 minutes of video. But the file size was 220MB!
Could someone recommend a program that captures and compresses video captured to avi in a small file size?
Hi bbrevolt,
You can convert the captured AVI to WMV using Windows Movie Maker. This is one of the better formats for emailing / streaming.
Make the resolution smaller (picture soze) and you'll get away with a lower bitrate which means a smaller end file size.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I would expect you need to change your recording options within the software. You sould be able to adjust the recording properties to get the files smaller. You would mainly be concerned with resolution and bitrate.
Google is your Friend
What's the best way to capture someone speaking from their webcam?
By chrisj in forum Newbie / General discussionsReplies: 25Last Post: 7th Jun 2011, 12:44 -
Webcam Capture Program Suggestions Please
By gtrgriff3 in forum Video Streaming DownloadingReplies: 9Last Post: 16th Jan 2009, 11:27 -
C-it WebCam Capture (Xirlink) Video Conversion
By PalPart in forum Newbie / General discussionsReplies: 0Last Post: 10th Aug 2008, 12:08 -
Best Webcam Capture Program
By Rowan88 in forum Capturing and VCRReplies: 0Last Post: 29th Feb 2008, 09:02 -
Record/capture webcam stream ?
By bat5hit in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2007, 17:33
