A friend bought a DZ-MV208E DVD camcorder but it didn't come with any software.
1st problem,
He plugs the camera into the PC via USB but there aren't any drivers included with the camera so XP won't recognise the camera.
2nd problem,
To get around the cable problem he put the RAM disc into his Pioneer 109 and was able to copy the video files to the PC. Unfortunately the copied files can't be opened as they are in some sort of UDF format.
Contact with Hitachi Australia has been totally fruitless.
Can anyone please provide some advice/help about what to do ?
Does the camera have a Firewire output? USB is generally for still frames and webcasting low quality output. You would need a Firewire computer card also. XP, at least SP1 or higher should then recognize the camera automatically. (Most of the time.
No firewire. Just USB and it's only 1.1 at that.
The better way to go is putting the RAM disc in the PC but we're not sure how to make the data on the disc usable because of the UDF thing. -
Sorry, apparently it doesn't have Firewire. I think you need a DVD drive that can read DVD RAM discs. I don't believe the Pioneer 109 does.
I think these are the USB drivers, though: http://dvdcam-pc.support.hitachi.ca/en/download/dl.asp -
Thanks for that. The only downloads we've been able to find so far have only been driver updates. We'll see how this one goes.
109 does read RAM
http://www.pioneeraus.com.au/computer/dvdwriters/dvr109/index.html#anch_0 -
I am having the same problem. my camere DZ-BX35E also came from australia and I cant transfer the stuff on the disc to the computer because of the coding, there is no type of usb or firewire hookup, I have to go directly from disc to computer. HOW do I do this ?
How to burn the video camcorder files to a dvd
By MikeN in forum Newbie / General discussionsReplies: 6Last Post: 27th Dec 2011, 13:36 -
Uploading video from Hitachi camcorder to PC (XP)
By jasi621 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 8th Nov 2010, 00:19 -
DVD from a HD Camcorder video
By pskim in forum Newbie / General discussionsReplies: 3Last Post: 11th Apr 2010, 06:46 -
HD Video to DVD and buying decision HD camcorder
By ddinc in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Dec 2009, 07:17 -
Video (from camcorder) has no sound on DVD
By FLVidiot in forum Newbie / General discussionsReplies: 0Last Post: 16th Sep 2008, 17:23
