hi all i have two avi files that make up a movie i want to join them so there one movie the problem is this.
taken from avicodec
File : 229 MB (229 MB), duration: 0:47:00, type: AVI, 1 audio stream(s), quality: 24 %
Video : 209 MB, 623 Kbps, 25.0 fps, 352*272 (4:3), DX50 = DivXNetworks Divx v5,
Audio : 20 MB, 64 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3,
the other is also taken from avicodec
File : 218 MB (218 MB), duration: 0:47:13, type: AVI, 1 audio stream(s), quality: 31 %
Video : 175 MB, 519 Kbps, 25.0 fps, 400*304 (4:3), DX50 = DivXNetworks Divx v5,
Audio : 43 MB, 128 Kbps, 44100 Hz, 2 channels, 0x55 = MPEG Layer-3,
i followed a tut from here to change the codec so they matched but the bitrate is different (i dont know if that makes a differnce)
but the audio is also different which i know will cause problems i cant join them usuing virtual dub until the data matches as it wont let me so any help i would be grateful for
thankyou in advance
You can reencode the audio with VirtualDub too. Go to Audio -> Full Processing Mode. Then Audio -> Conversion. Set the parameters as necessary. I recommend also enabling High Qulity. Then Audio -> Compression... Select an MP3 codec and set the prameters.Originally Posted by hades8840
converting raw teltext data into other subtitle formats
By zorr00000 in forum SubtitleReplies: 8Last Post: 18th Jan 2012, 06:12 -
Huffyuv+pcmaudio 2 clips = diff data formats?!?!
By duhmez in forum EditingReplies: 2Last Post: 19th Apr 2011, 20:48 -
Playing AVI Movies as data files with menus
By shans in forum Authoring (DVD)Replies: 25Last Post: 10th Mar 2011, 10:43 -
AVI Files to DVD data disc
By rossco3333 in forum Authoring (DVD)Replies: 6Last Post: 27th Oct 2008, 08:20 -
Problems burning avi/xvid as data files
By deuceswild13 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jul 2008, 02:49
