hi all just wondering if there is something that can check a disc to see if there is any glicthes on the disc itself b4 you soend the time burning onto it only to find out its a coaster
thankyou
A visual inspection is all you've got.
Look for uneven dye or spots.If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Eh, no, not really. But if you have a BenQ drive you can use QScan to test tracking errors and focus errors on your blanks before burning. It will also recommend a burning speed. Don't know how much stock to put in it, it has recommended speeds of from 4x to 12x on individual discs from the same spindle of 8x TYs. They all, however, burnt successfully, play fine, and scan at 97% or above. (If you think such tests are useful. Me? I dunno).
Pull! Bang! Darn!
Block errors in video extracted from DVD-RAM disc
By kosdi07 in forum DVD RippingReplies: 0Last Post: 2nd Mar 2012, 15:45 -
how would I check for errors in multiple videos??
By bidomo in forum Video ConversionReplies: 6Last Post: 6th Jun 2011, 21:13 -
Check DVD for errors
By Happichap in forum TestReplies: 1Last Post: 10th Mar 2011, 06:53 -
How to check for encoding errors
By Dark Alpha in forum Video ConversionReplies: 5Last Post: 30th Jan 2010, 10:25 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
