quick question about TMPGEnc DVD Author...
i've only used it a few times... i forget how powerful, and how nice it really is.
when formatting a custom menu, is it possible to use my own image, but not have the image "stretched" out as DVD Author does (and other programs' custom menus do as well). I'm trying to be consise-- i hope you know what i mean.
if an option to not "stretch" the menu background pic doesn't exist, then suppose i use Photoshop to create an image that will match the dimensions of what these menus are looking for. what are the ideal dimensions of an image for use in a DVD authoring program's menu background?
For exampe, Nero Vision Express takes the image that you give it, and doesn't stretch it at all-- which leaves a border around the image if it doesn't fill the screen horizontally. Nero Burning ROM, when using the VCD menu options, gives you the option to either center or stretch the image.
advice for a non-stretched image in TmpgEnc DVD author?
