Can someone help me with the following problem?
When I burn a DVD on my Philips HDRW 720 then it works fine on the Philips HDRW 720 itself and also on “regular” DVD players like my Pioneer DV-444. This is valid for DVD-R and DVD-RW.
However, when I like to read the DVD on my PC there are problems. When it is a DVD-R then the computer recognizes it, plays it with a DVD player but using it with DVD Shrink there are error messages “Invalid DVD navigation structure” or “DVD Shrink encountered a problem”. The problem is bigger with DVD-RW, then a PC sometimes does not recognize the DVD (depending on the type of DVD player)
First off....your machine is a +R machine...but no biggie....we know what you mean.
What version of DVDShrink do you have? It sounds like you may have an older version since the Philips Disc problem was solved by the creator of DVDShrink several versions ago.
You need to "Protect" your +RW discs in order for them to work properly in almost everything. And you need to finalize the +R discs in order for the computer and other devices to recognize them properly.
I have an older DVDR985 machine and have no problems with compatibility with either DVD Players or DVD Burners/Roms.
I use DVDShrink and DVDDecrypter almost faithfully with my Philips created discs. -
I'm running Shrink 3.2 and I still have this problem with the discs from my Philips 615.
I use DVD decryptor instead, although you can only rip one VTS at a time. -
What version of shrink are you using? I am using 3.2 and it never works on +RW discs created on my 985. No problem with dvdecrypter.Originally Posted by hech54
Does Philips BDP3406/F7 play PAL DVDs on NTSC TV?
By whachano in forum DVD & Blu-ray PlayersReplies: 22Last Post: 3rd Aug 2013, 00:37 -
Problems playing MKV 720 & 1080 - Not enough PC ?
By NotSoEasy in forum Software PlayingReplies: 8Last Post: 7th May 2010, 13:30 -
Philips DVP5992 & PAL DVDs
By kinemax in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Feb 2009, 12:03 -
My DVDs play 2x on Philips 5982
By Gritz in forum Newbie / General discussionsReplies: 0Last Post: 21st Sep 2007, 21:57 -
Problems with Disney/Pixar DVDs on Philips DVP642
By deesto in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jul 2007, 20:11
