Haven't used -rw discs. My understanding from the past couple of years here is:
Best dvd-r are: Tayio Yuden
Best cheap dvd-r are: Riteks
Never purchased -rw discs. Would ritek or TY be recommended here also? Thanks
p.s. must be reasonably priced -rw discs, perhaps the best of the cheap brands.
Results 1 to 18 of 18
If you wan't -RW then price should be no object as you are reusing them.
Try Philips -RW
00000000 00 6C 00 00 01 40 D6 FD 9E D8 21 00 02 0D 06 07 .l...@....!.....
00000010 88 65 0D 00 03 52 49 54 45 4B 57 00 04 30 31 00 .e...RITEKW..01.
00000020 00 00 00 00 05 00 88 00 00 00 00 00 06 10 08 05 ................Regards,
Rob -
I would not recommend RITEKW DVD-RW discs, at least none of the ones sold in the USA.
TDK, Fuji (MKM, MCC), SONY ... those are good.Want my help? Ask here! (not via PM!)
If you must use -RW, then by all means use -RW.
However, if your drive does +RW, then choose +RW. It's much better than -RW.
Verbatim/MCC makes good +RW that are widely available. -
Thanks. I've read a lot of great things about Verbatim. It turns out my standalone Pioneer 533 will burn -rw at 6x speed. Most media sold in the US is 2x (ritek does have it at 4x). I've read in a post here that in the UK you can get Verbatim 6x. Too bad we can't find Verbatim 4x in the US, or atleast I can't. Thanks for the input.
p.s. I couldn't find any Fuji, TDK -rw discs either -
JVC 4x -RW seems pretty good, if you can find it. I know Fry's carries it, and HH Gregg. It's available online too obviously.
Originally Posted by Gen-AnWant my help? Ask here! (not via PM!)
found some at staples for $14 after instant savings for a pack of 25 Sony dvd-rw, but it doesn't say the speed. I'm wondering if they're 1x
http://www.staples.com/webapp/wcs/stores/servlet/StaplesProductDisplay?storeId=10001&n...&cmArea=SEARCH -
RICOHJPNW11
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Originally Posted by Bodysurf
25 bucks, but you might do better elsewhere or on sale. Haven't seen any 6x here from *any* mfr., though. I don't think it would help me if I could find it, since the burner in the 520 is 4x. -
Originally Posted by bnbhohaI don't have a bad attitude...
Life has a bad attitude! -
Originally Posted by leebo
That packages looks like the 1x RW discs, I have 50 of them.
And I bought them this year.Want my help? Ask here! (not via PM!)
Well if you don't see it it must not be. I'll scratch it out on my spindles.I don't have a bad attitude...
I was looking at the online pictures.
So you're saying you bought some 4x at your local Staples?Want my help? Ask here! (not via PM!)
Uh, I just went by to Staples and picked some up. It does say in tiny letters that this is 1x-2x on the -rw, but I don't see that on the website. The +rw is 4x. Okay deal for $15.
Lordsmurf: are these MKM or MCC? Thanks -
Smurf, you said you had purchased some before and you didn't see where it says 4X. Didn't mean to be rude.
Anyway, it is printed on the +RW spindles 1X-4X. Very tiny print though.
I went to 2 Staples stores for these. The first one didn't have any and the second didn't either, but a helpful employee asked if I needed help and she checked in the back and came out with 2 cases of them.I don't have a bad attitude...
Originally Posted by bnbhohaGod Bless
1920x800 MKV -> Bluray disc. Any good option?
By Asterra in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2011, 20:48 -
Good simple batch converter - recommendations please!
By plasticmonkey in forum Video ConversionReplies: 0Last Post: 6th Dec 2010, 07:11 -
A good, "easy" program that can edit a DVR disc?
By Arglameth in forum EditingReplies: 1Last Post: 23rd Feb 2009, 09:58 -
Do you know any good site about copy gaming disc?
By coody in forum ComputerReplies: 2Last Post: 6th Jan 2009, 15:43 -
What's a good format to use to put several videos on one disc?
By DVDNewb in forum Video ConversionReplies: 2Last Post: 21st Jul 2007, 12:28
