Well is like this I make my menu all goes well but when I play my menu
under adobe encore the highlight goes from the first item to the last and then all stays highlight all the shortcuts work well and everything but is the
highlight. Please reply thanks in advantage.
jma
Can you reexplain? Maybe with some screenshotsUse your head, Side Step the Traps, Snake through the chaos with a SmoothNoodleMaps -
Okay, after a reread I may have it. I bet when you made your buttons you just did a copy and paste. For some reason this can cause problems in encore. Why? Got me. A way to see if this is the problem is to clcik on the route buttons option. The little icon at the bottom of the menu screen that looks like the up and down left and right arrows on the dvd remote. Once that is on. With the arrow tool, start clicking on each of your buttons and try to notice the range of the button. My quess is you've got one button that when you copied and pasted it. Then moved it into position, streated it's boudaries, instead of keeping them within the area of the button.
The effeect would be. When you press down when previewing the menu in Encore. You would move from the first menu item to the next one in the list and if that one was the qulprit, it's boudries would contain the highlights for ALL the other menu items on your screen. (You following here?) Kinda hard to explain).
How do you fix this?
Delete the bad item, and recreate it.
If you try to resize it, you will end up resizing the image and highlight that are within the item itself. just delete it and try again. It's a paiin.Use your head, Side Step the Traps, Snake through the chaos with a SmoothNoodleMaps
New Adobe Photoshop image deblurring algorithm
By poisondeathray in forum Latest Video NewsReplies: 3Last Post: 14th Oct 2011, 00:12 -
Computer trouble with Adobe Premiere & Photoshop CS4
By monks19 in forum ComputerReplies: 3Last Post: 10th Jan 2011, 13:42 -
Picture as Menu Background in Adobe Photoshop
By boofer in forum Authoring (DVD)Replies: 3Last Post: 16th Oct 2008, 02:41 -
Adobe Photoshop Elements 6
By Mållgan in forum Capturing and VCRReplies: 0Last Post: 2nd Aug 2008, 05:15 -
Problems with Adobe Photoshop Trial Download
By kerrex_2006 in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2007, 12:19
