I'm encoding a Sony network webcam (Z30) with Windows Media Encoder, but the camera is attached to the encoding PC via a router (rather than plugging it straight in via a capture card). As a result, the only way to encode the stream is via a screen capture, as WM Encoder won't recognise an IP address as a "source". Is there any way of getting WM Encoder to recognise an IP as a source?
Results 1 to 1 of 1
Aspect Ratio Looks Different After Encoding VHS Source
By jrodefeld in forum Video ConversionReplies: 1Last Post: 2nd Jul 2011, 10:35 -
Dye-based vs metal-based: which will last longer?
By RedZone in forum Authoring (Blu-ray)Replies: 11Last Post: 11th May 2010, 22:30 -
Open source Firewal (GNU/GPL license), based on PC hardware solutions...
By retroborg in forum ComputerReplies: 2Last Post: 8th Mar 2010, 07:05 -
Installing the open source encoding components
By three-cushion in forum MacReplies: 3Last Post: 25th Nov 2007, 22:07 -
Encoding XVID from 10 FPS source
By dilly323 in forum DVD RippingReplies: 5Last Post: 15th Nov 2007, 01:00
