My Celeron 800 runs on a Win2k box. When I load any video file into VirtualDub 1.4.7 I can only select Divx 4.11 under compression but not Divx 3.11a which is also installed. It's getting even worse when I try to capture compressed. When entering capture mode the codec select box does not list any Divx codec anymore, so I can only capture to Intel Indeo, Cinepak and Microsoft Video1.
According to the Virtualdub help this is because the codec used must support the format the video captured in. So I tried almost any format even customs ones from 120 x something to 640 x something but to no avail.
I do need much frames or high resolution. 352 x something suits me fine and should cause no problems for my low end system. However, which format do I have to use for DIVX capturing?
TIA!
don't forget to specify "YUY2" under format - then you will see DivX as a codec in compression menu (and Huffyuv if installed)
Best COMPRESSED video editing format in Premiere?
By Namie in forum EditingReplies: 8Last Post: 6th Jan 2010, 20:11 -
Which is least compressed format?
By vid83 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2008, 19:59 -
Virtualdub - What did I do wrong?
By tigerb in forum Newbie / General discussionsReplies: 7Last Post: 15th Oct 2008, 11:42 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
compressed capture with composite
By benaw in forum Capturing and VCRReplies: 2Last Post: 20th Nov 2007, 08:09
