I use Nero (the free version that came with the burner) to put my home movies on DVD. I can only get about 1 GB onto the disc. Is this a software problem? All videos and slideshows show on the DVD index, but only the first few will play. Any solutions?
Results 1 to 9 of 9
What media?
How are you creating them and authoring the DVD?
A9757367What happens when you try to play the ones that won't play, error message or nothing?
What space used does windows show for the DVD, Maybe it isn't all being burned.
Good Luck -
I am using a hp DVD+RW 4.7 GB disc, and I've also tried imation DVD-R.Originally Posted by TBoneit
I use nerovision to author the DVD.
There is no indication that the DVD has not burned successfully. No error messages from the computer of the DVD player. Some videos or slideshows just aren't there, although they are listed in the index.
Windows shows 4.7 GB of burnable space on the DVDs. -
1GB? Could this be because you might be trying to burn a disc using FAT32? (Just a wild guess.)
1gb is 1 full .vob (1024mb)...are all the (missing) vobs present on your DVD?
No2: We want Information.
No6: You wont get it! -
In short, your hard drive is formatted to either FAT32 or NTFS. FAT32 has the limitation that no file can be over 4GB, which is particularly relevant in DVD operations, considering that the capacity of a SL DVD is 4.38 GB or thereabouts.Originally Posted by bazzab
https://www.videohelp.com/dvd#structOriginally Posted by bazzabIf in doubt, Google it.
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 04:06 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
