Just bought a new Dell laptop, the DVD burner is Sony DW-D56A.
Did not do much to it yet. Can someone tell me if this drive is any good? Any firmware to flash? Any way to flash it to be region-free?
Results 1 to 11 of 11
That would all be on the Dell.com site
http://www.kiva.org/about -
I checked the "DVD Writer" section of Videohelp.com. It's listed as a Lite-On OEM.
The latest Dell-sanctioned firmware for this drive is PDS7. The latest D56A firmware (Sony-sanctioned, but not Dell-sanctioned) is PFS3. Based on the LiteOn SOSW-852S.
Firmwares for this drive can be found here:
http://codeguys.rpc1.org/firmwares.html#cat_slimdvdrw
(rpc1.org is currently down for a few days for a server relocation, so try the link in a few days if it's not working) -
I guess the real question is should I upgrade the firmware? If so, what advantage(s) would I get from the new firmware?
If it's working fine, don't mess with it. Generally, newer firmwares will give you better media support (improved burn quality on existing types, and support for media that may be unsupported on older firmwares).Originally Posted by mis3
BTW, for region-free, you can just use LtnRPC to disable or reset the counter... -
Now, I have tried to burn a few DVDs and resutled in a few coasters already.
Anyway, I am calling Dell soon to complain. Should I ask for a NEC replacement? I know that my laptop does come with either Sony or NEC. -
Dell issued a new firmware this week (at least for me, it might have come out sooner). There is a utility on your laptop that should automatically inform you.
I don't have a bad attitude...
Life has a bad attitude! -
that sucks, coasters the first time
I would get a nec, to many problems with lite-on or sony, which is a lite-on drive. -
Really? Can you put an NEC burner in a Dell laptop?
Sure. All laptop DVD burners are made to the same industry specifications for slimline drives. Often, these drives can get encased in some sort of enclosure (like the enclosure used by Dell for their "media bay" drives), but within these enclosures, they're all the same. The only thing to look out for is the drive's slave/master settings (since most slimline drives come with it hard-coded in the firmware or in non-volatile memory and don't have DIP switches to change them anymore) and also the bezel.Originally Posted by leebo
Can't play HD videos with Dell laptop
By neworldman in forum ComputerReplies: 2Last Post: 29th Aug 2010, 02:24 -
Dell Laptop Problems
By bevills1 in forum ComputerReplies: 8Last Post: 27th Aug 2010, 12:04 -
Asus or Dell Laptop
By Poppa_Meth in forum ComputerReplies: 2Last Post: 1st Mar 2010, 22:11 -
DVD burner compatibility with Dell
By LWC in forum ComputerReplies: 14Last Post: 29th Nov 2008, 09:17 -
DVD Burner for a Dell laptop
By PhoneMatt in forum ComputerReplies: 5Last Post: 26th Oct 2007, 13:15
