hello
I've been backing up a few movies using dvd shrink and Nero 6
But I'm not sure I'm using Nero properly. An old guide I was following tells me to choose DVD ROM (UDF/ISO) when selecting the type I'm going to burn. But A guide on this site says select DVD-VIDEO.
I'm a bit confused now, do you think I've ruined some backups?
Which should I use? I'm not sure if this makes any difference but sometimes I need to do stuff like use a still picture to replace extras which brings the file sizes down.
Thanks for helping
Bletch.
I use Nero 6.3.1.17 with no problems. I let Shrink do the Nero setup and burning, and does it automatically, so there's nothing to choose.
Use DVDDecryter to burn if you are concerned about better compatibility.
When I use Nero directly, I use the DVD Video format. I Just drop all the contents of the VIDEO_TS folder in and burn. Never had any burn failures or incompatibility with my players. -
I'd suggest trying http://members.dodo.net.au/~jimmalenko/NeroExpress.htm - it doesn't get much easier than that
If in doubt, Google it. -
If you're using DVDSHrink to compress your DVD's, why not just set the option in DVDSHrink to use DVD Decrypter as the burning engine and then you don't have to do any more manual work
Once its been shrunk by DVD Shrink, it will automatically load up DVD Decrypter and start burning your DVD for you without you having to do anything
When you select backup, simply choose the backup target as ISO Image file and burn with DVD DEcrypter
As long as you have installed DVD Decrypter then you have no need to worry about using Nero, besides MY personal preference is to avoid using Nero for DVD video discs I had far too many problems with skipping and stuttering so changed to using DVD Decrypter as the burning engine, all my problems disapperaed and it wasn't the media I tested that -
Hey guys
I did as you recommended and downloaded & used DvdDecryper - setting Shrink up to make it use Decrypter to burn, Quick and painless!
Just made a backup and went into all the extras etc.. seems to work fine
There's still loads of options to tick in Decryter's settings section, shall I just leave them as is?
Thanks!
Bletch -
Yes(unless you want the tray to eject),most options are for ripping.Originally Posted by Bletch
I gave up on Nero long ago and I only use RecordNow or DVDDecrypter.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2008, 00:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10
