Hi
I use TmpGenc Mpeg Editor to edit some of the shows I capture from TV, I have a 2 hour movie that I captured and I wanted to cut the commercials before and after the movie. I do so and save it to a new file
The problem is when I burn that file with Nero into a DVD. I notice that the first half of the movie plays well with Picture and Sound in Sync then they start to get out of sync in the second half.
This has been going with any movie edited with MPEG Editor and written with Nero
Can you help
Results 1 to 11 of 11
So the patient says to the doctor, "Doc, my arm hurts whenever I raise it over my head!" So the doctor replies, "Then don't raise it over your head!!!"
Isolate the issue by trying different editors (VideoReDo, MPEG Video Wizard) and burners (DVD Decrypter, Roxio, PrassiONE) and noting the results. -
I doubt there is any way Nero Burn can do that. Data is Data
http://www.kiva.org/about -
Thanks a lot for the help, I wanted to try other tools but wasnt sure which ones to try. Thanks for listing them.
I didnt know that DVD Decrypter can burn mpg file, only thought it can burn dvd files
Will give it a try and see, I think it might be the mpeg editor not Nero but will see -
I tried MPEG Video Wizard then Transcoding and buring with NERO and same problem occured, Audio is out of Sync from Video, so it seems that NERO Transcoding is the problem. Now I have to try another tool
Any comments are still appreciated -
I've had that problem a while back but i editied the captured video with vegas movie studio, used ffmpeggui to change the audio into ac3,authored it with dvd-lab pro using the extracted ac3, and burned with nero...worked perfectly
make sure that the video is in sync in the original captured video, as well as the video after you edit it...check the last bit of the movie to see if is in sync
Hope this helps -
If i may make a suggestion. After you have done your file your just trying to burn it. Instead of using Nero after you have used Tpmgenc Mpeg Editor and you have your files. Use Tpmgenc DvD Author 1.6, it cam author make your menus etc and then burn the movie/video it lacks some of the features of your more complex programs but what it does it....it does very well simple and straight forward if you havnt used it before after install you can use it with no trouble even without reading on it. Try it and see if it doesnt resolve your issue
I tried TmpGenc Dvd Author but the AUDIO_TS folder comes out always emty while the VIDEO_TS folder is full with vob files, is there something wrong as i notice that there is no sound
Originally Posted by Akronica
You can also try IfoEdit...heres how:
1. use tmpgenc to make the video a m2v file.
2. use ffmpeggui to make the ac3 audio
3. a) open up IfoEdit
b) go to DVD Author at the top
c) Click Author new dvd
d) open the m2v and the ac3 files from step 1 and 2
e) Click OK.
this will make your files into vob;s and whatnot...all you have to do is import the files into nero and burn...this way nero doesnt convert..it just burns (what its supposed to do)....so if you dont want menus then this is a good way to go...i used to do this before i discovered the wonders of dvd lab -
Thanks that worked fine finally
Also, TmpGenc DVD Author finally worked out when I burned the DVD, audio and video are in Sync.
Thanks for all the hlep
TMPGEnc MPEG Editor 3 updated with WTV input support
By gyoshi in forum Latest Video NewsReplies: 0Last Post: 3rd Mar 2010, 19:34 -
Womble or TMPGEnc MPEG Editor?
By Mike99 in forum EditingReplies: 14Last Post: 11th Aug 2008, 09:32 -
Quad Core used with Pinnacle 11 & Mpeg Editor 3
By jaffacaique in forum EditingReplies: 9Last Post: 3rd Aug 2008, 09:42 -
TMPGEnc MPEG Editor 3 Trial (English version) available!
By gyoshi in forum Latest Video NewsReplies: 2Last Post: 6th May 2008, 09:25 -
TMPGEnc MPEG Editor 2.0 PREMIUM
By jaffacaique in forum EditingReplies: 0Last Post: 10th Oct 2007, 03:53
