request deletion
Results 1 to 10 of 10
Use "DVD mpeg2enc" target format with "Burn" and "Decode with mplayer" options enabled. The vertical position of the subtitles can be defined with "Pos".
When the process is finished, the mpv and mpa files will also have been muxed into mpg and then authored into VIDEO_TS. When using "Decode with mplayer" with NTSC FILM video, audio sync problems may arise. In that case, there is a last "hard" way to proceed, that is, to first encode to "DivX mencoder" -with- subtitles, then encode the resulting AVI to "DVD ffmpeg", or to "DVD mpeg2enc" (with "Decode with Quicktime"): the source already containing burned subtitles, they will also be in the final DVD.
Retrieving AVI video after deletion and overwriting
By Jongi12 in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2012, 11:11 -
Account deletion?
By tgp1994@gmail.com in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2011, 01:21 -
Avs2Wav request
By lovyagin in forum AudioReplies: 3Last Post: 26th Aug 2009, 04:32 -
Account Deletion
By Deluge in forum Off topicReplies: 7Last Post: 9th Oct 2008, 22:35 -
Windows 3.1 request
By Darth Paris in forum ComputerReplies: 8Last Post: 14th May 2007, 14:24
