I can't seem to get Power DVD to open any DVD files that are located on my PC. Should I be opening a file other that the VIDEO_TS file? Does this program only open files from teh DVD Drive itself?
You can get it by clicking the little drive icon at the bottom of the screen. You can open DVD data and media data from there.
sorry, ignore my previous reply
...I didn't read properly that the files were on your computer. However if you have them on a DVD disc, follow my previous advice
Play MKV files in Power DVD
By prabhakarlad in forum Software PlayingReplies: 2Last Post: 11th Oct 2010, 01:46 -
Power DVD 10 Won't SD DVD From Hard Drive
By wulf109 in forum Software PlayingReplies: 1Last Post: 16th Apr 2010, 01:10 -
Corrupted AVI files after power failure
By Babaloo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Nov 2009, 15:58 -
authoring x264 .mkv files for Power Hour DVD
By TraceBusta in forum Authoring (DVD)Replies: 1Last Post: 1st May 2009, 15:51 -
Can't open older TMPGEnc DVD Author files in latest version
By steelborn in forum Authoring (DVD)Replies: 1Last Post: 19th Feb 2008, 13:55
