I'm planning on buying a new Dell W1900 LCD TV. I have my PC built and have the ATI HDTV Wonder card. I was wondering if its possible to combine the card with a Motorola DCT6200 box that I am going to rent from comcast. If possible, I would like to be able to split the cable so I can get HDTV on the capture card and the TV part of the LCD TV. Am I able to do that?
Any help would be greatly appreciated.
The ATI HDTV Wonder will only tune over the air ATSC DTV and over the air analog TV.
It will also tune the analog cable channels and accept a S-Video analog input + audio from the cable box. I will not tune cable digital channels or cable HD channels.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
So there is no possible way to be able to record ESPN HD or HBO HD with the ati hdtv wonder and a motorola DCT6200? If not, is there any capture that can work with this to achieve what im trying to do?
I realized that the ATI capture card wasn't what I was looking for so I gave that to my brother for his PC. I have been searching the internet and I can't seem to find any component video capture cards, do these exist? If not, then what are my options as far as getting off-the-air HDTV reception from a motorola cable box?
Not that I have seen.Originally Posted by cwalk
Try IEEE-1394 (see links above)Recommends: Kiva.org - Loans that change lives.
I just got my firewire card and I captured some HD content from ABC, it seems that ESPN HD is protected from capturing. I followed the directions from the thread that EdDV posted and converted the HD content using HDTVtoMPEG2, but when I play the converted file I don't have any audio, the video looks fine, but the audio isn't there. Am I doing something wrong?
Look what I found-a Motorola DCH3200 set-top box for use with Comcast cable
By zoobie in forum DVB / IPTVReplies: 7Last Post: 15th Dec 2010, 21:27 -
Problem: DVD-R Recording with Motorola QIP6416-2 DVR FiOS TV Box
By Plarocks in forum DVD & Blu-ray RecordersReplies: 12Last Post: 4th Jun 2010, 20:03 -
4 digit code for motorola digital box link to polaroid DVR
By majel in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2007, 14:46 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 23:39 -
HDTV Cable Card from motorola
By lein in forum DVB / IPTVReplies: 4Last Post: 4th Oct 2007, 16:49
