I created a .bin of a VCD using TSCV. I mounted this image in D-Tools and it worked fine. Then I burned the image to a CD using CDRWIN following the guide on this site. But now the problems begin :
1. My PC-DVD drive does not recognize the cd at all and says "Please insert a CD" when I double click.
2. My HP Cd-Rewriter drive reads the CD after a lot of blinking and then although it shows the correct directory structure , it only shows 1 MB used,0 MB free.
3. WinDVD cannot play the VCD.
4. MS Media Player takes a long time to load the DAT file and then is not able to play the beginning and the end of it, with random boxes appearing during the other parts also.
Does that mean the CD is bad ? Or did I do something wrong ?
Please help.
Anil
Although I have never used TSCV the fact the image plays fine under D-tools suggests to me that it was some sort of a bad burn. Perhaps if you try burning with FireBurner this will solve the problem, otherwise, you will need help from somebody experienced with TSCV
Goodluck
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 02:07 -
extract music from bin image?
By pensioner in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2011, 23:01 -
dvd burning error when make a bootable dvd image
By junian116 in forum Authoring (DVD)Replies: 1Last Post: 5th Apr 2011, 03:58 -
Best Image Quality burning AVI to DVD..
By UncleRuss in forum MacReplies: 9Last Post: 29th Jul 2009, 04:06 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 04:29
