Hi,
i'm a newbie and I"m just starting to learn all this......but I want to know if there are any programs that makes it very easy to create dvd menus .... what would you recommend? how about if I want to make complex professional looking dvd menus, what program does that? thx
I like the flexibility and stability of DVD-lab Pro. It's one of the few authoring programs (that I've come across) that allows me to customize just about anything. Even for a newbie like me, the interface was manageable and appealing.
DVD Lab by far is #1 imo! ......very flexible, but it takes some time to learn. If you want TOTAL control over your menus and you're a good learner then DVD Lab is the way to go. If you like the simplexity of templates and pre-made navigation buttons and stuff like that then you'll probably want to go with TDA, Movie Factory, etc. I suggest that you try them all out little by little and see what one is right for you.
"kk"
What Program was used to create these menus?
By BIGD22 in forum Authoring (DVD)Replies: 14Last Post: 21st Nov 2011, 18:43 -
Build DVD Structure without Menus and Create them Separately
By Bruno AUgusto in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2011, 12:50 -
How do I create custom DVD menus?
By aple in forum Newbie / General discussionsReplies: 6Last Post: 21st Jul 2011, 20:25 -
Best program to create a DVD (with menus) from MP4s?
By namrufmot in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2010, 21:18 -
Best program to create a DVD with menus for home movies???
By orbital517 in forum Authoring (DVD)Replies: 5Last Post: 12th May 2007, 21:14
