I made a xvid from an mpeg2 program stream with ffmpegx (Video Codec: XviD [.avi] (ffmpeg) was what I used). I gave the video to someone who I think is on a PC, and he can play the video fine, but says VirtualDub can't find the decompressor for this file. He also said the FourCC code (xvid) isn't in capital letters, and maybe there would be less compatibility problems if I could use XVID instead xvid.
Another person suggested I use FourCC changer which he thought was installed with the divx codec, but he uses a PC too. I can't find that, but I found a program called AviFourCCChangerX 0.1 at macupdate:
http://www.macupdate.com/info.php/id/10603
Will the VirtualDub problem be solved with a change in the FourCC code? Should I even worry about all this?
tell them to uninstall divx & install the xvid codec, during the installation it will ask them if you want the xvid codec to handle the decompression of all fourCC codecs, tell it yes.
cannot change region code from 1 to 2
By decocal in forum Software PlayingReplies: 6Last Post: 16th Oct 2009, 04:27 -
Can't change region code
By The-One in forum Blu-ray RippingReplies: 0Last Post: 22nd Mar 2009, 11:19 -
FOURCC Change
By anirban in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2008, 20:35 -
Change XP Code Possible?
By Gritz in forum ComputerReplies: 2Last Post: 28th Oct 2007, 17:46 -
Change Time/Date Code?
By jorwex in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th May 2007, 14:37
