Results 1 to 14 of 14
    Jul 2005
    How do i change AR (aspect ratio) on a full DVD (vob files)? Sorry if this question have already been asked several times :/ but my searching didnt get no good results. Thanks bye!
  2. Kinda a vague question. Ripping, editing, or burning?
    Quality is my policy.
    Jul 2005
    i downloaded a movie in the dvd format aka vob files and the people was tall and skinny aka bad AR so i want to change the AR from 4:3 to 16:4(i think its 4 dont know right now my brain is wacked but WS ar) with witch program can i do that? i want it to be a DVD just change AR.
  4. Any Mpeg2 encoder will do it.
    Jul 2005
    kk, can u suggest one? cheers m8
    Jul 2005
    Hum no mpeg2 encoder can use .vob files? someone know a good program for changing Aspect ratio on .vob files? dont wanna convert to AVI i wanna keep the dvd, just quick change the AR
  7. Member kush's Avatar
    Jul 2004
    Near "Pacific Park", USA
    To reencode the files, you will want to "demultiplex" the .VOBS..Meaning separate the video (m2v/mpg/whatever) and audio (ac3/mpa/mp2/whatever).
    But, I'm not sure that you even need to re-encode your stuff..You say tall and skinny, ie: a widescreen (16:9/etc) source shown in standard 4:3 (like broadcast tv). It sounds like you could just edit the .IFO files..Just do a search in the forum/guides on vobedit/ifoedit..Not easy to use programs for the noob, but guides someone should be able to point you in the right direction with one of them...And as a friendly reminder if you try this - BACKUP your .IFO/.BUP files before you edit them.
    Jul 2005
    k, thanks! will try this in the morning. Oh i can use DVD lab pro for demultiplexing right? k thanks for the help m8! Take care
  9. You can easily change the AR flag of MPEG2 files with ReStream.
  10. couldnt you just change the ratio in the ifo files? This would be 1000 times quicker and a possible quick solution to your problem. Just use ifoedit and change the ratio to 16x9 instead of 4:3 which it may be set to now
  11. Correct the WS-flag using IFOEdit: Open relevant IFO file (VTS_xx_0.IFO, xx=title number), click on VTSI_MAT, scroll down, double-click on line 200 (hex) and change aspect ratio, OK, then save the file. You can find the "open" and "save" buttoms on the left bottom side of the IFOEdit screen.
    Jul 2005
    Okay! u guys are great thanks for all help! cheers
    Jul 2005
    Baldrick, as stated before i search and didnt get no results, and ive already got some great answers from some great guys. Take care
