Results 1 to 13 of 13
  1. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Hey guys, I dont know a thing about Car audio systems but hopefully you guys can help me out.
    I have a Cassette player head unit in the front, and its hooked up to a 6 Disc CD Changer in the trunk. My question is, can I place the CD Changer somewhere inside the car instead of the trunk, and if so, where would be an ideal place to put it (mount it)? I hate having to go back there everytime I feel like switching CD's.
    Any help is appreciated.
    By the way, the car system is Alpine TDM-7544, and the CD-Changer is CHM-S601. Not top of the line stuff, but as long as it plays CD's, I'm good.
    "The statement below is True,
    The statement above is False"
  2. An option is to buy a head unit that plays MP3/WMA/AAC,I just installed one and now I can put 10 hours of music on one CD-RW.They also sell media centers for cars:a 20GB HD that you can link to your PC via wireless or USB.
    www.crutchfield.com
  3. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Yeah, in fact I'm actually debating on just getting one. But I figured I'd give "replacing the CD-Changer" a try before I buy one just yet.
  4. I removed my glove box & custom-mounted a Clarion 12-disc changer with fiber-optic connection in its place.
    You might also vertically mount it between the front seats if you have bucket seats.
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  5. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    So then it really doesn't matter where its at? I also thought it had to lay horizontally to even work, apparently thats not true.
    Could I just, perhaps, lay it on the floor on the passangers side? Or does it have to be mounted?
  6. Originally Posted by lowlow42
    I believe most are designed to be mounted either vertically or horizontally (mine is). Your owner's manual should clarify this.
    It'll probably be less susceptible to skipping if mounted.
    George Carlin
  7. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    That makes sense.
    As far as a manual goes, when I bought my car (used) the owner didn't include any type manual for the audio system.
    I'll probably play with it over the weekend. Thanks for your help!
  8. Member jackal70058's Avatar
    Jul 2004
    Louisiana
    Does not matter where you mount CD changer. As long as you can wire it back to head unit.
    Most CD Changer made so you can mount them in any dirrection. They bounce around in-car so they know it should be able to hold CDs well.
    www.crutchfield.com
    It great if you download much music through the Internet, or if you hold alot of music in you computer. If you buy only CDs, it does nothing for you. It depends much about what you do. If you still not knowing what you need you can ask someone at the Best Buy store.
  9. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Thanks for the reply! I'll keep that in mind.
  10. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Where is the wire that leads to the CD Changer, is it pretty easy to access? Or do I have to cut that fabric and all that stuff?
  11. Member jackal70058's Avatar
    Jul 2004
    Louisiana
    Depend on you car. You have to look at it an see where it goes. Without seeing it I not can tell you. Usually, there is no cutting, you may have remove kick panels or other. Also depend on how it was install (after market or factory) and how it hooking into the head unit.
  12. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Ok, I'm going to stop by 1 of my friend's house then. I think he installs head units, so I'm sure he'll be able to help with out with this.
    Thanks again!
  13. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Today I unmounted the CD-Changer from my trunk and was able to access the wire/cable that connects to it. I now have it located in my glovebox, so everything worked out alright. Thanks for the help guys.
