I have a question regarding converting AVIs to MPEG-2 for playback on a DVD player. I tried using mpeg2enc encoder which worked, but my Sony DVD player does not recognize the AC3 audio (the audio is there, but the Dolby "double D" does not illuminate). The mpeg2enc encoder also takes a lot longer, usually 20 hours or so for one AVI, whereas the ffmpeg only takes eight. This is with a 450MHz G4.
I used the "Set 3:2" option when I used mpeg2enc which retained the widescreen aspect of the videos I converted. When I used the ffmpeg converter, I lose the widescreen and the picture fills up the entire TV screen.
Can I use the "Autosize" option under the Video options to set the 3:2 like mpeg2enc, or is there something I am missing?
"Set 3:2" has nothing to do with image aspect ratio, as it is a framerate pulldown option. When encoding with ffmpeg engine, you should enable "Decode with Quicktime" if you want to benefit from its auto-letterboxing feature. If you don't enable "Decode with Quicktime" you can use the manual letterbox in the Filters tab to add black bars (don't forget to subtract the same amount of pixels you're adding from the image size so as the total doesn't vary).
mp4 to mpeg with ffmpeg - no audio
By ilpilo in forum Video ConversionReplies: 15Last Post: 29th Mar 2012, 10:17 -
MPEG I II IV conversions
By cerebro in forum ffmpegX general discussionReplies: 5Last Post: 14th Oct 2009, 16:49 -
mpeg-ts and .ts conversions
By nirbhayn in forum DVB / IPTVReplies: 3Last Post: 30th Aug 2009, 19:00 -
How to use ffmpeg? .MOD to .MPEG to ffmeg.
By CAH1 in forum ffmpegX general discussionReplies: 17Last Post: 19th Mar 2009, 21:22 -
mpeg conversion using ffmpeg
By rbtechno in forum Video ConversionReplies: 1Last Post: 1st Dec 2007, 04:48
