  1. I recently upgraded to the latest version of GUI for dvdauthor (0.95.1). On most players (my standalone, and even InterVideo WinDVD 4) produce perfect results. However, when viewing with PowerDVD (using Version 4.0.13.2409) my title menu comes out completely black. The links are still clickable if you know where they would be, but the whole screen is rendered black. I've seen some posts about increasing the time for the title frame, but I feel like there is something else amiss. The title is there, it’s just not viewable.
    My Config File: guidvdauthor.zip
    Anybody have a similar problem or ideas?
  2. It is a known problem. If you do not plan to use the DVD on a Pioneer SA Player: Load the settings, tab 'Permanent' and change the 'Number of frames for still menus' to 1. If you plan to use the DVD on a Pioneer SA Player use any number higher than 10 (this seems to work on all players, but increases the size of still menues a little bit). In the next version I will use a default of 1 frame again (PowerDVD is quite common, Pioneer SA Players rather rare).
  3. Thank you for your quick reply, that resolved the problem, works great now.
