How do I make the menu which I made in DVD Lab loop smoothly during playback? This menu is set to run infinitely that's why after 30 seconds which is the length of the video I use for the menu, it will pause maybe for about 5 seconds and then repeat the playback.
All DVDs do this. The best way to hide this is to have the video end simulating a "still" image, thus hiding the switch back to the beginning.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
I know that but this one I made, the pause I think is longer than the regular/commercial dvds, maybe longer than the 5 seconds I mentioned.
Dont go past 10 seconds, it takes time to keep loading and reload the clip. Its dependent on your DVD player if it can handle it on the fly like that, 30 seconds is pushing it.
Quality is my policy. -
Originally Posted by Stormin Norman
By the way, I played this dvd in 2 different players, a pioneer and a samsung. Both played the dvd the same way. -
It is probably that your player is slower to read from burned disks that pressed (commercial) disks. Again, there is little you can do to fix this as it is player dependent. You could try different disks to see if your player reads a particular brand better.
Read my blog here.
Vegas to DVD Lab Pro motion menu issues
By outerspacerace in forum Authoring (DVD)Replies: 4Last Post: 23rd Jun 2008, 20:28 -
Jumping Text on Motion Menu in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 21st May 2008, 07:32 -
Delayed Links, Motion Menu and DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 14Last Post: 30th Apr 2008, 01:33 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 12:03 -
how to make motion menu in dvd-lab pro that like this
By 741210 in forum Authoring (DVD)Replies: 10Last Post: 23rd Aug 2007, 22:53
