I have a strange problem that I cannot figure out. I have a Hauppauge WinTV PVR USB2. System specs in my profile are current. My problem is when I record/capture, after 45 minutes to an hour or so, the picture begins to go “slow motion” and become jerky. Occasionally it will completely freeze. If it just remains jerky the end result recording does not show this effect. If I stop recording and just watch, it immediately goes away and looks normal. I have also noticed that as it gets slower and slower, the delay becomes longer. There is a 1 second delay normally and it will get as long a 6 seconds. The cpu usage never get high and at the beginning of the capture, I can multitask and do things with no apparent ill effect. The problem only presents itself after recording has been going on awhile.
I have tried closing out everything in my system tray, switching around USB ports, installing a new PCI 4 hub board and several suggestions from Hauppauge tech support to no avail. My frustration factor is getting high.
Anyone else experience this? Any suggestions appreciated.
Thanks.
Have you tried using a usb powered hub so the device dosent draw power from the usb subsystem power on the motherboard .
This may be worth considering ...
Hauppauge pvr usb2 driver problem after XP install....
By pinetop in forum Capturing and VCRReplies: 14Last Post: 3rd Jul 2010, 01:35 -
Hauppauge WinTv USB2 Power supply
By canadateck in forum Capturing and VCRReplies: 4Last Post: 14th Nov 2008, 14:46 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 03:19 -
Hauppauge WinTV PVR USB2 locks up in Vista Premium after 20 min
By SpaceCowboy9 in forum Capturing and VCRReplies: 5Last Post: 10th Aug 2007, 08:19 -
Dilema: Hauppauge 99016 or WINTV-PVR-USB2?
By WetLight in forum Capturing and VCRReplies: 0Last Post: 11th Jun 2007, 05:42
