  1. Banned
    Mar 2005
    India
    I've AVI Joiner software. I want to join two AVI files of different resolutions: 480 X 272 and 352 X 208 and different frame rates : 23.97 and 29.97. These cannot be joined using AVI Joiner, coz of different resolutions and frame rates. Please suggest me a method to make the frame rates and resolutions of both the files equal, so that, I can join them.
    you must reencode, use for example virtualdub, dr.divx.
  3. Banned
    Mar 2005
    India
    yes, i know, I've to re-encode....but how ??
    Pls explain the procedure to change frame rate and resolution in virtualdub or dr.divx
  4. Banned
    Mar 2005
    India
    I changed the frame rate and resolution of second AVI file from 352 X 208 to 480 X 272 and it's frame rate to 23.97fps using TMPGEnc XPress. But, now when I joined these two files using AVI Joiner, its output is again very dirty. Pls suggest another tool for joining two or more AVI files.
    Aug 2003
    filemerger joins avi's or mpeg's
  6. Banned
    Mar 2005
    India
    Pls specify the full name of the software. There are a lot of softwares with that name like: Eagle Eyes File Merger, ISS FileMerger etc..
    Aug 2003
    FileMerger written by Maxwell Sayles
