Hi
I need to use a Lossless Codec.
This is because I need to back up avi files created in Premiere Pro 1.5 onto DVD, so that I can edit them in the future.
So I downloaded MSU.
My problem;
I cannot access or even see this new Codec I have downloaded in PP.
I have checked to see if it is installed - it is;
(On XP Home: Control Panel / Sounds & Audio Devices / Hardware / Video Codecs / Properties)
The codec and default settings are fine: msulvc05lossless codec[MSUD]
On PP this is how I am trying to locate the codec;
I select the Clip / Project Settings / Video Rendering / Configure / . . . .
the ONLY option I have is: Radius Cinpak.
(I have downloaded other codecs - they don't show up either!).
I would appreciate some help on this one.
Thank you in advance - Stephen
Premiere will not accept all codecs.
Thanks LordSmurf.
Do you know what Lossless Codecs PP does accept?
Thanks. -
Cancel - I've found it.
For anyone else with the same problem;
Start a New Project / Custom Settings / Video Rendering / Compressor / Configure. -
Wouldn't you be exporting your existing avi format to to this lossless codec?Originally Posted by Dear Prudence
If it were me I'd do a test before committing to this storage format.
Export to "new codec", or externally convert the output file.
Set Premiere to original avi project format (e.g. DV-AVI).
Import "new codec" and see if it conforms back to project format.
If you are converting your whole project to this new codec, make sure you can import from and export to the target format.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
What codec did Adobe Premiere Pro originally use, and...
By Cyrax9 in forum MacReplies: 1Last Post: 4th Sep 2010, 16:17 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27 -
HD Video from VirtualDub to Premiere Pro for editing - What codec is best?
By gliebetronics in forum Video ConversionReplies: 6Last Post: 14th Jul 2008, 12:57
Hi
