i wonder if there's anyway to burn a DVD with 2 subtitles file? can u plz plz show me how can i do that? i have one movie (.avi) with subtitle file(.srt) in English, now i want to translate it into French and burn into DVD with 2 subtitles option, can u please let me know how can i do that? thanks alot!
Results 1 to 10 of 10
Edit and translate the srt with notepad...or download subs from www.extratitles.to or www.babelfish.altavista.com to french.
Convert to dvd with avi2dvd, diko, thefilmmachine
or the latest divxtodvd, it supports subs...not sure if it supports more than one sub though.
https://www.videohelp.com/forum/viewtopic.php?p=1293730#1293730 -
Acctually, in case of serveral DivX Certified Player, you just put the avi and subtitles in the same folder and it will be switchable.
For my case I put: Name.avi; name.english.srt; name.vietnamese.srt
Anyway, the subtitles might look small and languages other than English can be displayed wrong. -
The key is authoring.
Convert your AVI like any other AVI.
and then use an advanced authoring software (TMPGENC DVD Author doesn't work).
Most of them are expansive, if you want the free alternative, use DVDauthor (Gui for DVDAuthor or DVDAuthorGUI).
You just need the add the subtitle when you add the video. -
Originally Posted by qknetC2D 6300@3.21Ghz|Vista Ultimate x64|P5B-Dlx Wifi|Transcend 4 GB 800 Mhz|XFX 8800GT 512 MB Alpha Dog Edition|Samsung 19" 940BW|1.5 TeraByte Storage|ASUS SATA DVDRW|Altec Lansing ATP5|APC 800 Smart UPS.
DVDlab lets you add more than one sub (*.sub;*.srt;*.ssa;*.son;*.sst). Just under the movie and audio when you add it to the timeline. You can have more than one audio and also more than one sub. It doesn't show 2 right away so just add the first one and the second option will be visible when you return to that panel. After you add 2 you can add a third and so on if you want.
Ah heck.......
I didn't notice someone (333) resurrected an old topic and asked a totally different question
Oh well you win some you lose some.
btw) that old subtitle link from Baldrick is now parked.
How to add Vietnamese subtitle ??
By caube in forum SubtitleReplies: 31Last Post: 17th Jan 2011, 17:16 -
How do i add two .srt files into Subtitle Workshop??
By emilroh in forum SubtitleReplies: 1Last Post: 16th Feb 2009, 13:41 -
create/add subtitle
By akakiami in forum DVD RippingReplies: 1Last Post: 15th Aug 2008, 04:40 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 14:37 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 14:17
