Wonder if I could connect my old analogue camcorder to DVD recorder like CYBERHOME 1600 (or any other) using the audio and video cables to convert old analogue tapes ?
Would in Europe the format of the DVD output of the Recorder be PAL. Is there a way to convert to NTSC (so it would play on a US DVD player).
Thanks a lot.
That would work but remember Cyberhome is not that good..possible hic-cups with audio recording...
Yes.Originally Posted by marcelr
PAL signal will be recorded as PAL. NTSC will be recorded as NTSC. At least that is how I understand funcionality of Cyberhome recorders. I don't believe there is recorder that can do conversion from one format to another. If your recordings are PAL, your US friends will need DVD Player that can play PAL disc on NTSC TV. They are available... I had couple of them.Originally Posted by marcelrPinnacle Studio 8 and DV home video editing (ver.9 already home) -
Try setting the format of the recorder to ntsc and see if it converts the input and records thus.
A simple way is to record in pal then get a cheap dvd player that will play the pal disc and output a ntsc signal then record that !
Simple and it works.PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
analogue video capture from ultrasound machine without pc
By vito321 in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2012, 13:02 -
analogue video from VHS tapes to PC
By teka1 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 09:32 -
analogue video enhancer?
By Jac26 in forum MacReplies: 16Last Post: 4th Jul 2009, 07:14 -
Capture analogue (eg. VHS, analogue camcorder) - AVI or MPEG?
By ManUtdFans in forum Capturing and VCRReplies: 3Last Post: 18th Jan 2009, 18:29 -
Analogue video capture on Vista x64
By tennant in forum Capturing and VCRReplies: 3Last Post: 28th Jun 2008, 09:03
