hello , I know this has been a problem posted before and i know it will be something simple that i have over looked... after looking over forums and hours of reading i am trying to encode a XviD-MDX.avi movie to dvd and all i keep getting is XviD-MDX.avi.ff.m2v and no video ts folders. i have tried diferent types of avi files and encode with dvdffmpegx and dvdmpeg2enc. would really apperciate some help. and as you can probably tell i am a total novice! I have a g5 1.8dual 250hd, thanks
Wait until a "Finished" or "Failed" message appears in the Progress window. If the message says "Finished" you should see a VIDEO_TS folder in the destination path. If not, check that there are no spaces or special characters in your paths and try again. If the message is "Failed", post your process output (blue "i" icon).
tried again there was still no ts folders and there where no spaces or any other characters other than full stops in the path. it was finished.
the i info was :
Encoding started on Sat Aug 6 17:09:42 BST 2005
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] input: frame rate: 30000/1001 fps (~29.970030)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x480, 720x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 29.970 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] output: frame rate: 30000/1001 fps (~29.970030)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] Selecting DVD output profile
INFO: [mpeg2enc] Assuming norm NTSC
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/ryanharrison/Desktop/movies/Monty.Python.Live.at.the.Hollywoo982.avi.ff.m2v
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO)
INFO: [mpeg2enc] Bitrate: 4000 KBit/s
INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 0 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 138346!
INFO: [mpeg2enc] Guesstimated final muxed size = 1096631278
error: movie contains no audio tracks!
my file wont play in quicktime but plays fine in VLC but i dont dont know how to check if im in "decode in quicktime setting".
sorry after looking further on the net i realised that my quicktime needed updating with the proper components to play divx.avi i have updated it and quicktime now plays the avi movie fine and with sound... I will try to encode the avi again with ffmpegx, ill post back my results, thanks
I've had the same problem. I've tried to encode an DivX avi (and it's MOV equivilent, made via DivX Doctor)(incidentally, the DIVX plays fine on my version of Quicktime) and never get a VIDEO_TS file either. Furthermore, it only completely encodes (to a mov.ff.m2v) when I put the Autosize into 16:9 mode. When I don't, I just get a "failed" message and this:
Encoding started on Fri Oct 28 15:02:03 PDT 2005
INFO: [yuvscaler] input: frame size: 720x576 pixels (622080 bytes)
INFO: [yuvscaler] from 720x576, take 720x576+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x576, 720x576 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] output: frame size: 720x576 pixels (622080 bytes)
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/thomassorensen/Desktop/Torrents/Movies/GalaxyExpress999.avi.ff.m2v
INFO: [mpeg2enc] Vertical size: 576 pel
INFO: [mpeg2enc] Bitrate: 3746 KBit/s
**ERROR: [mpeg2enc] Sample rate is greater than permitted in specified Level
Can anybody help?
