Hi@all!
I´ve done my 1st rip. With Smartripper and my NEC-DV5700 it takes about 4 hours to get the *.vob-files out of my DVD.
(Speed check tells me about 0,3X speed while ripping is that normal? what can I do?
Next step "DVD2Avi" runs in 30mins. Then TmpGenc lasts another 2-3 hours.
Pleas help a newbie
MK
Cant help you but that seems sooooo long to rip a dvd i can do it with my 16x dvd rom in about 15 to 25 mins no longer. shorter if i dont remove macrovision i also use smartripper
wow 4 hrs !!!! seem too long to me,
Have you enable DMA in your dvd drive? What is your dvd drive speed?
It is normal for DVD2avi to run 30 mins (without downsampling). I'm not sure about TMPGenc but TMPGenc 12a with pentium III 850 and 1 hour long movie should be around 5-6 hours. -
DAMN!!!!!!!! 4 hours to rip!!!!!!!!
make sure you have a working ASPI Layer
latest drivers for your drive
have DMA enbaled for both the DRive aHard drive
and thatmight help seed up your ripping speed and if you need the ASPI layer private message me
Whats your OS
ASPI might be the problem.
Check DMA
also make sure the disk is clean and the laser isn't having to cut through grim and then try to interpret the results. -
I've got the same DVD drive as you and mine only takes about 45 mins to rip a movie. Like the others mentioned, make sure you have a working ASPI layer installed and have DMA enabled.
I only dream in black & white...
MSN: paschendale@gmail.com -
What system do you have OS? CPU? Memory?
That is the key factor of speed of ripping and decoding
Try "Ripping directly to VCD,XVCD or SVCD from the DVD-ROM. How to rip with DVDx and encode TMPGEnc" from DVD RIP
It took me less than 3 hrs to complete ripping/decoding the DVD into SVCD format.
Need help on it, READ and FOLLOW the guide carefully.
Still need help then post it on this forum
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
i dont suggest it can really break your drive
How to keep track of how many hours PC has been used/on ?
By Noahtuck in forum ComputerReplies: 9Last Post: 3rd Apr 2012, 09:05 -
Which SD Card? How Many Hours?
By josel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 18th Sep 2011, 16:11 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 21:23 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 11:08 -
3 Hours.. HELP!
By Its Pink Ninja in forum Newbie / General discussionsReplies: 20Last Post: 15th Sep 2007, 18:33
