Hi all!
I'm ready to buy a system, but am undecided which chip to buy.
Thanks!!
Click on the button on the right that says "Compare". Good animation to explain the difference. Sounds like D is the way to go, but it is more expensive. Do some research to determine if the D chip runs hot- if so, look for a 3rd party heat sink that can handle it better than the stock Intel one. When you're rendering video footage and encoding, you often have 100% CPU usage for hours on end.
http://www.intel.com/business/bss/products/server/dual-core.htm?ppc_cid=vib|dualcor_b2b|k3668 -
Pentium D is better than Pentium 4. AMD Athlon 64 X2 is better than Pentium D. AMD 64 X2 is also cooler than Pentium D.
Look at this article:
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2484
Is a 2.8 Pentium 4 w/HT able to playback HD?
By GLE3 in forum ComputerReplies: 2Last Post: 25th Mar 2009, 11:36 -
Going from amd 9850 to pentium 9550
By johns0 in forum ComputerReplies: 1Last Post: 24th Sep 2008, 00:30 -
Pentium P4 SL7E2 = Northwood or Prescot ???
By blinky88 in forum ComputerReplies: 6Last Post: 4th Aug 2008, 15:26 -
Performace...Pentium D to Core 2 Duo
By ron spencer in forum ComputerReplies: 14Last Post: 31st Mar 2008, 18:42 -
3.4 Pentium 4 or 935 Pentium D?
By DarrellS in forum ComputerReplies: 6Last Post: 12th Jan 2008, 00:58
