Is it me or did you lose some of the advance editing features with the newer model of the cyberhome line of recorders. With the 1600 you cannot manually edit the chapters like you can with the 1500 and that is something good? You are stuck with where the unit auto places chapter markers instead of where you want them. Here is a review from Amazon.com on both units..... [ with most items when you get a newer model it has the older features as well as newer ones or improvments ] however with Cyberhome that is not the case. Read the product reviews below. I wish I had known this unit did not have this feature otherwise I would not have purchased it and took my chances with a bad power supply.
Amazon.com Product Description
One of the most affordable stand-alone DVD recorders to date, the CyberHome CH-DVR 1500 offers DVD+R and DVD+RW recording and high-resolution progressive-scan DVD playback, making it equally well suited for recording TV programs, archiving your home videos, and enjoying your favorite movies on a high-definition or HD-ready TV. As it's increasingly more common for standard DVD players to play DVD+R/+RW discs, this is a great way to share personal footage with distant loved ones.
With the CH-DVR 1500 you can digitally record superb picture and sound--up to six hours a disc, in your choice of resolution (only one hour at the highest-quality setting). Use the timer and scheduler for advance recording of up to eight favorite TV programs, or record "live" to disc at your whim. The recorder lets you add markers and thumbnail images with auto chapter or set chapter markers manually.
A major benefit of the DVD+RW (rewriteable) format is the ability to edit programs as you're making a disc, ensuring through handy add and delete buttons that you'll only commit to disc the segments you intend. Further, there's no finalization required before playback of DVD+RW--you can use DVD+RW discs pretty much the way you use VHS videotape, only without the cumbersome fast-forwarding and rewinding. DVD+R lets you edit--add, move, remove--but you can't reclaim recorded space once it's been burned, so your total disc length shrinks as you make cuts.
Front audio/video inputs (composite- and S-video) accommodate feeds from camcorders and other devices, and the recorder offers 9-bit analog-to-digital encoding from video sources. An onscreen disc title navigator gives you quick, easy access to your recordings.
As a player, the unit handles everything from DVD+R/+RW, DVD-Video, and DVD-R to VCD, SVCD, and CD-R/CD-RW, including CDs filled with MP3 music files. Progressive scanning doubles the scan lines of an interlaced signal by scanning all 525 lines in 1/60 of a second for each full pass. The higher-density video signal creates film-like DVD images with rich detail, extraordinary depth of field, and precise color reproduction.
Composite- and S-video outputs accommodate most televisions, and a choice of either PAL or NTSC video output lets you use the player/recorder with either monitor type. The unit offers an RF passthrough for TV tuning, but be aware that this channel signals from the onboard NTSC tuner only--not from DVDs. If you have an older TV without a composite-video (yellow RCA jack) input, you'll need an RF modulator to go between the DVD recorder and your TV.
Product Description DVR 1600
Get the functionality of a VCR in the form of a DVD player. This CyberHome Progressive Scan DVD Recorder has a built-in TV tuner so you can record your favorite programs live or with the timer. You also can connect to your VCR or camcorder and transfer VHS movies and video to DVD discs. Features: Progressive scan video; plays DVD, DVD+R/RW, VCD/SVCD, CD-R/RW, MP3, JPG and other disc types; records to DVD+R/RW; component, composite and S-video outputs; camcorder DV input, 1394 connector; decoding system, stereo analog and audio out, and coaxial digital audio input; in/out track selection; multifunction remote control; on-screen display; front and rear A/V input jacks; one-touch recorder and editing features; and multiple record modes for up to 6 hours of record time on 1DVD+R/RW disc. Imported. 2Hx9-1/2Wx13-3/4L".
Results 1 to 1 of 1
video player that can step forward/backwards and change play speed
By wildflow in forum Software PlayingReplies: 5Last Post: 5th Jul 2012, 19:16 -
Any one with a non working cyberhome dvr-1200 or 1600 will buy your remote
By therd3 in forum Newbie / General discussionsReplies: 0Last Post: 21st Sep 2010, 01:21 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
LG LRH-890 vs Pioneer DVR-550 - manual chapter points??
By Hookah_Bon in forum DVD & Blu-ray RecordersReplies: 0Last Post: 31st Jul 2007, 17:55
