Newb as can be when it comes to video, pardon the naivete.
OK, Im trying to join several avi files for a future DVD encode and burn. They AFAIK have the same resolution, data rate, framerate etc. But I keep stumbling into the same error with VirtualDub, it says "Cannot append segment, video streams have different sampling rates (23.97600 vs. 23.97600)". Thats not a typo, it says its the same sampling rate but Im getting the error anyway. How do I get around this? Appreciate any help.
Looks odd.
Probably not a good practice, but I've never had any trouble doing it with VirtualDubMod. You'll get the same or similar error but just click "No" and continue to append the segments.
Otherwise, you should be able to encode them individually and then join the resulting mpeg with TMpgEnc under Mpeg Tools to ensure compatibility.theHTPC.net
Find a cure for cancer by folding proteins! Join the Team 32 Folding@Home project (#3 worldwide!). Check us out here -
Do an All Forums search on "different sampling rates" and you'll find 45 possibly similar threads - including https://www.videohelp.com/forum/viewtopic.php?p=1316049#1316049 :
Originally Posted by bugster
It's possibly because of VBR MP3 audio. So use any virtualdub to extract the audio to PCM - guide here - (or alternatively recompress to CBR MP3,) and add that stream back into your AVIs using virtualdubmod, and then try joining them. Either that or just leave the AVIs as-is, and convert each one to DVD_compliant MPEG seperately, and let your authoring software join them. There's no need to join the AVIs prior to encoding
If in doubt, Google it. -
You'd be amazed by how many peeople think that this must be done before encoding to DVD. It happens all the timeOriginally Posted by liverkick
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm might be worth a read. It gives you a lot of pointers in regards to choosing the correct bitrates and frame sizes and I daresay you'll find it pretty helpful if using TMPGEnc.If in doubt, Google it. -
Oh man thats gonna be a huge help (especially the bitrate stuff, boy was I lost there). Really appreciate it.
I'll undoubtedly get confused and come back with more questions in no time.
Joining AVI Files in VirtualDub.
By eliqush in forum EditingReplies: 12Last Post: 6th Jul 2009, 04:31 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 02:09 -
joining 2 AVI files via VirtualDub or another program
By cfs6254 in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2008, 13:15 -
Simplest way to join AVI files with diffferent Sampling rates.
By dagerousdave in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2007, 08:03 -
Joining avi files with Virtualdub
By JaredKnight in forum EditingReplies: 10Last Post: 8th Jul 2007, 21:45
