Hello everyone.
This is my first post please forgive me if i am posting in the wrong section.
I have 4 avi files of a TV Show the total duration will be 5 hours and 20 minuts or something around that..
and i want to create a dvd from these on a single DVD5 disc so please help me with this.. i would like to know which program should i use and a guide please.. i am a noob but not a total noob..
Thanks for your time.![]()
Results 1 to 19 of 19
That would give you a bitrate of approx 1676, which at full D1 or half D1 would look awful. If you must use one disc then I would encode at VCD specs -
PAL
Video:
1150 kbit/sec MPEG-1
352 x 288 pixels
25 frames/second
Audio:
44100 Hz
224 kbit/sec MPEG-1 Layer2
NTSC/NTSC Film
Video:
352 x 240 pixels
29,97 frames/second
23,976 frames/second NTSC Film
Audio:
44100 Hz
Have a look in the guide section, there's loads of AVI-VCD guides. If you go along this route use TDA to author/make menu's, it's very easy.He's a liar and a murderer, and I say that with all due respect. -
use gui4ffmpeg on the AVI's to create mpeg2 files for the dvd, then...
use a program like TMPGEnc DVD Author to make the DVD and allow the outputed files to go over the size limit of a DVD5, then create the DVD folders...
Then use DVDshrink to re-size the output files so they may fit on a DVD5.... -
Have you looked for / tried any programs yet ?
Have you looked for / found any guides ?
We shouldn't have to do the searching for you
https://www.videohelp.com/tools?toolsearch=&s=&orderby=Name&hits=50&convert=AVI+to+DVD&...+or+List+tools
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=AVI+to+DVD&h...or+List+Guides
If one-click wonders are what you're after, I'd try the free version of DivxToDVD. Follow the download link in the tools section, and look for the link to the old freeware version on VSO's website.
Or if you want to get your hands dirty, pony up using http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm .
As steveryan points out, there's pretty much no way in hell you're gonna retain any sort of quality if you try to fit 5 hrs 20 min onto a DVD-5 without reducing your frame size somewhat. You might consider putting 2 AVIs on each DVD, and then you could use a bitrate of around 3600, which would be plenty for Half D1 (352 x 480/576).If in doubt, Google it. -
yeah i did a lot searches.. before i ask here i did try my hands on nero.. but it ended up with 12gig.. but now thanks to you guys.. i am more in proper way of doing it.. than before.. thanks again..
5h20min wont look that good, just to let ya know.....your probably gonna get a fair amount of blockiness in your output........not tryin to knock ya for doing it or anything, just forewarning you......it will look something slightly better than vcd, but DEFINATELY not up to commercial dvd standards.
This will make a perfectly crap quality disc.
This will make a perfectly crap quality discyou guys whats the worry!!!5h20min wont look that good, just to let ya know.....your probably gonna get a fair amount of blockiness in your output
i get 9.5hrs on 4.3gig dvd with very good quality (the best vcd==vhs) with no blocks!!!, so 5.5hrs will be ok!!!!
i sugest you try 1/2 d1 if your worried about the low res :PCOOKIEEE!!! -
No.Originally Posted by the * dude
VCD is less than half the resolution that VHS was, and it totally lacks in interlace.Want my help? Ask here! (not via PM!)
ok i know...slip of the tonge
yeah but made from a good source (dvd), you can't really tell on pb..... when i used to make xvcds(pro-logic
just wanted to state th quality isn't as bad as being portrayed!!!?!!COOKIEEE!!! -
What process are you using?Originally Posted by the * dudeHave a nice Day
leading to a questioning of your skills given this quote...
joke! :P
you really can't expect too much from avi sources... the ones the guy has got aren't prob worthy of a 8mbis enc
COOKIEEE!!! -
i've never tried to make a vcd and i never want to..if you are concerned at all with quality you will either burn it to a DL or split it up.
VCD's come in 2 flavors:
1) Really blocky
2) Really blurry -
tmpeg low res dvd template... with the motion serach set to high cbr ~1000kbs,,, audio ac3 160kbs (2ch).... with only the output YUV selected in the quantise matrix tab...
if you got the time use vbr....
i leave the audio as a wav & let dvdauthour re-enc the audio & authour! 8)COOKIEEE!!! -
you can't say till youve made one proper..all the ones that are ready made and avaiable are really crappy encodes..... so thoses flavours apply to them....
mates used to cry when they watched a proper vcd, even at home on a 33'' 4:3 tv!!!!!COOKIEEE!!! -
Running some filters over the video can improve the result. Even hand held home video can be made to work at 1150CBR VCD standards.Originally Posted by greymalkin
Each solution has its pro's and con's.Have a nice Day -
Ok don't worry guys.. LOL..
i made the dvd and it doesn't really look bad.. it is like a vhs quality.. so i am happy with the out come..
this is what i did..
1. using TMPGnc i converted them to vcd quality mpg
2. Using TDA made the dvd folder and the total amount was 3.8 GB
3. and then using nero burned the dvd files to disc..
and it is perfect for me.. -
And that's all that matters. As you can tell from the various responses everyone has a different opinion what is good or bad in terms of quality. People still like to post questions that start off with, "What is a good..." or "What is the best...", and it invariably starts a debate.Originally Posted by tatail"Art is making something out of nothing and selling it." - Frank Zappa
encoded video duration different than vob duration
By fatcharlie in forum Video ConversionReplies: 9Last Post: 4th Dec 2011, 11:04 -
Flv video has no duration
By jace89 in forum Software PlayingReplies: 5Last Post: 9th Feb 2009, 07:16 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36 -
Missing duration
By DuBsTaR in forum ComputerReplies: 5Last Post: 16th Sep 2007, 16:39 -
Duration per media?
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 14th May 2007, 09:22
