This is what I am doing. I have an avi file on my hard drive, and I converted it to dvd format with divxtodvd, then burned it with copytodvd3 trial version. Afterward my audio and video are out of sync. They were not as the avi file. This happened on three different movies. Is this a simple fix involving a codec or something? Please help, I would appreciate it. I am burning them at 1X.
I just viewed my converted dvd files and the problem is evident there as well. Is there another application i could try for converting avi to dvd format?
I have never had DivxtoDVD create an out of sync movie, but that doesn't mean it isn't possible. Open the original AVI in virtualdub and save it out as an uncompressed wav file. Use besweet or similar to create an AC3 file. Demux your new DVD to get the mpeg video stream, then remux and reauthor using the new audio. This should correct the problem.
Read my blog here.
Audio Conversion out of sync
By Silsur in forum AudioReplies: 8Last Post: 13th Oct 2009, 17:45 -
AVI Conversion - Audio out of sync
By pinovecs in forum Video ConversionReplies: 3Last Post: 17th Oct 2008, 16:11 -
HD dvd conversion, audio sync problem...
By BigJeebz in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 21:52 -
WMV video and audio slightly out of sync on conversion to AVI
By Calidore in forum Video ConversionReplies: 8Last Post: 10th Jul 2007, 08:48 -
No audio when doing AVI -> DVD conversion
By molamola in forum Video ConversionReplies: 5Last Post: 27th May 2007, 09:04
