Hi everyone
I recently purchased an LG DVD recorder and am having some issues.
I use a DVD RW to record the material, using Video Mode. The result is a playable DVD. What I then do is rip it over to the hardd rive and re-author with tmpgenc, after adding the menu to the dvd (as I don't like the features of the recorder for the menu).
No matter what I try I can't get the episodes to be in sync all the way through.
I have tried doing it from the DVD drive itself, copying to the HDD then authroing, extracting the video and audio through dvd decryter and then re-authoring, but still I get the same problems.
Can anyone suggest a way for me to do it?
Specs for my PC are:
Win XP Home SP2
256mb RAM
2.4GHz
Any help would be appreciated
