I'm trying to avoid manually re-encoding a series of files (around 200) by using a simple script. The problem is that I don't know anything about them.
Basically, I would like to take my original video, extract the audio to .wav, recompress it, re-encode the video using xvid, all the while adding black bars around the video and merging the compressed audio.
Is there a simple tutorial or way to do this? I was hoping there would be something like Photoshop has; something that remebers where you click and what settings you used.
VirtualDub has a thing called "Job Control" which can sort-of do what you want to do, but you'd need to load up each file I think ...
You can save your processing settings as well ...
Maybe a combination of the two, as well as virtualdub in CLI mode might be able to do the job as painlessly as possible ?If in doubt, Google it.
GUI Tool created for batch video tasks
By VirtualDoobMon in forum ProgrammingReplies: 10Last Post: 10th Jun 2019, 09:50 -
How to create multiple tasks for FFMPEG?
By sandrushe in forum Video ConversionReplies: 3Last Post: 16th Dec 2011, 05:41 -
After conversion software that can perform several specific tasks...
By ShorN in forum Video ConversionReplies: 0Last Post: 23rd Feb 2010, 18:24 -
Premiere CS2 hanging during simple tasks
By Schwez in forum EditingReplies: 2Last Post: 4th Oct 2008, 17:17 -
Adding multiple title tasks to a video
By nam207 in forum EditingReplies: 1Last Post: 22nd Nov 2007, 09:02
