Hello,
I've been converting for about a year now without problems. I always used TMPGenc MpegTools to cut the mpg files and this always worked fine for me.
Till now.....
A week ago I downloaded TMPGenc 2.02 and used it to cut an mpg file. Somehow the Merge&Edit wouldn't open any newly created mpg file. The buttons and bar all faded grey / unuseable. Sometimes I received a message about audio-headers, sometimes it simply crashes, or the program suddenly closes. (Older created mpg files did work without problem)
Tried installing different versions of TMPGenc tried to find the problem but couldn't solve it, so totally formatted the harddrive (had some other problems since installing a none WinXP compatible steering wheel).
After reinstalling everything. TMPGenc 2.02 worked fine again...I THOUGHT....but just one time. After the first cutting I get a problem I had before again. The program TMPGenc closes EVERYTIME after I selected the part I want to cut and hit the run button (right after the error message, which I previously could simply ignore, like many of you with XP do without problem.)
After days of searching for the problem I still haven't solved it. The only solution I found is using TMPGenc 0.11e or older. These can still do the cutting job. All newer versions 1.2 and up give the same problems.
Personally I think the problem is in TMPGenc 2.02. Somewhere during the first use, it writes something somewhere in the registry, which is being read by all versions of 1.2 and up. Removing and reinstalling TMPGenc (whatever version)doesn't remove this setting and only version older then version 1.2 won't read this register setting..... Might it be something like that ???
MAYBE ?
Someone ?
Really need the help with it.
Greetz
Mars-L
Hi,
I've been getting an error message after selecting the segment to cut for quite a few TMPGEnc versions, always been able to click OK the RUN. Sorry I can't help more.
Cheers. -
hrm...before you cut, try playing the movie in the preview window for a second and then pausing it
afterwards, cut as usual....this might work...and if it does, u have to do this everytime u cut....
Cutting MTS: splitter problem
By cheerful in forum EditingReplies: 3Last Post: 6th Jun 2012, 19:26 -
Virtualdub kernel32 error, TMPGEnc cutting video
By koberulz in forum Newbie / General discussionsReplies: 5Last Post: 11th Apr 2012, 11:36 -
Little problem-Cutting Scenes-Ideas?
By n3ur0 in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 08:44 -
TMPGEnc DVD Author 1.6 cutting a movie short?
By FizzFozz in forum Newbie / General discussionsReplies: 0Last Post: 21st Jun 2008, 11:20 -
problem with cutting AVI in half with VirtualDub.
By eroy in forum EditingReplies: 1Last Post: 27th Dec 2007, 06:53
