I was wondering if anyone has any ideas how to do this. I have already attemped to do this with DVDshrink, however I'm not convinced the disc burnt is fully compatible with all players. When burning dual layer discs, I like to use Recordnow max 7.3, as the results are always very compatible. The problem with the files produced by DVDshrink, is that RNM 7.3 would not burn them (some error - can't remember what it was), so I set DVDshrink to ISO mode and burnt with DVDdecrypter.
What I need is some way of merging the files and then letting DVDshrink do it's job, anyone any ideas??????
Do you want both discs on one DL disc? If so then I would use DVD Shrink on both discs (movie only, no shrinking) Then use re-author mode,import both of the discs you have just created, shrink, output as ISO, burn with DVD Decrypter.
He's a liar and a murderer, and I say that with all due respect. -
Tried that already, that doesn't produce a very good compatible disc, i need some way of combining the two discs and allowing RNM 7.3 to do the burning as RNM 7.3 has the LB problem licked, DVDdecrypter solution isn't that good. IMO, I have burnt DL discs with DVDdec and RNM before, RNM produces a better disc which works in more devices.
I have Piodata 108, does auto DVD-rom bitset for DVD+R DL, is there any other way anyone knows how to combine the films, there must be another technique I could try.
to join the files,you could always use dvd2one.
thats quite a good little programme.
as for compressing to one dvd+R DL,thats sacrilige,it NEEDS the DTS soundtrack,it MUST have the DTS soundtrack. lolLifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
Newb Help Please - LOTR Extended Edition
By dpend in forum Blu-ray RippingReplies: 7Last Post: 5th Jul 2011, 12:21 -
LOTR extended editions hits bluray - you buying?
By yoda313 in forum Off topicReplies: 1Last Post: 20th Apr 2011, 07:14 -
Born of Hope - LOTR fan film
By freebird73717 in forum Off topicReplies: 0Last Post: 23rd Jan 2010, 14:19 -
LOTR Bluray preorder now available - theatrical release only for now
By yoda313 in forum Off topicReplies: 3Last Post: 16th Jul 2009, 17:52 -
Multiple DVDs one file(LOTR EEs to be exact)
By filanwizard in forum DVD RippingReplies: 2Last Post: 21st Aug 2007, 22:39
