Hi there....
Got some family movies on a dual layered dvd disc, but it won't play in my pioneer player.....are they not supported yet...or do I need to do something different? Single layers play fine, but not this....any help would be grateful....
thanks in advance.
M.
It is possible that your Pioneer doesn't play Dual layer DVD's. Which player is it?
I assume it was a dvd+r dl disc ... your pioneer doesn't support +r/rw discs so therefore won't play a +r/rw dl disc
look over there <----
on the left side of the board under "DVD Players""To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
That's the Pioneer DVR-320 DVD Recorder? If so, it does not play DVD+R dual layer discs, does play +R single layer though.
Try to find a modified firmware for your burner to set the booktype to dvd-rom.Improves the compatability to about 90%.
bmiller,ont.canada
Anyone tried or had good luck with these TDK Dual Layer discs?
By terryj in forum MediaReplies: 2Last Post: 14th Feb 2010, 05:02 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Burning to dual Layer discs
By Mastablastacious in forum DVD RippingReplies: 19Last Post: 5th Feb 2008, 19:50 -
Having trouble with dual layer discs
By red69 in forum Authoring (DVD)Replies: 6Last Post: 8th Sep 2007, 05:16 -
Getting I/O Errors While Burning Dual Layer Discs
By VanCity in forum Newbie / General discussionsReplies: 5Last Post: 1st Jun 2007, 00:35
