Hi,
Does anyone have first hand good luck with stand-alone DVD players that can play "user burned" DL DVD+R (ritek)? Basically play anything I throw at it. I live in the US.
I have spent the afternoon perusing reviews, and the closest I come to sucess is the Philips DVP 642.
I have an older SONY that can't, it stutters/freezes on second layer.
Thanks in advance.
O.
pioneer dv-270, dv-271, dv-275 .. they're all the same player, just different model #'s for different retail outlets.
I found that one about an hour after I asked the question. Thanks, I can get it for $50. Considering the cost of this do it yourself course so far, another $50 won't hurt.
O. -
I found it at Tweeters. http://www.tweeters.com. That should be a real price and availability. While they may try to upgrade you when you get to the store, if they say available, it's available.
O. -
Originally Posted by orion940
My Sony Sony DVP-NS715P pauses for one second
My Cyberhome CHDVD-500 plays through the layer change seamlessly
My Magnavox MDV456/16 plays through the layer change seamlessly
My Panasonic DMR-E10 DVD Recorder pauses slightly on the change
My Sony would have major hicups on the 2nd layer if I burned over 2.4x so my advice would be to try a slower burn speed. -
I've been burning at 2.4 all along. With the RiTek and the Plextor716, any attempts at anything faster is suicidal.
In doing some experimenting, I have come to the conclusion that many others before me have--Ritek is iffy media. The ones that fail to play on the hardware I am just chalking up to crap media.
I still might pick up that Pioneer, I could use it in another room.
Thanks to all who gave ideas/suggestions.
O.
My AG-1980 suddenly won't play tapes. Any suggestions?
By Mini-Me in forum Capturing and VCRReplies: 5Last Post: 26th May 2011, 15:47 -
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Dvd player suggestions
By sweetcheeks82 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th May 2010, 06:41 -
Tax Refund = New DVD Player... Suggestions please?
By ufcdave in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Jan 2010, 14:17
