Hi im new at using DVD Author 1.5.2 and ran into some problems.
Heres what I want to do:
I've recorded a tv program onto my dvd recorder and burned it onto a DVD.
I wish to create menus for the program and also edit the chapters. The dvd works fine on both my PC and my dvd player.
The problem:
I have a list of vob files which i would like to add to my project.
VTS_01_1.VOB
VTS_02_1.VOB
VTS_02_2.VOB
VTS_02_3.VOB
VTS_03_1.VOB
VTS_04_1.VOB
VTS_05_1.VOB
I start TDA and when I click Add file , I can add all files except VTS_02_2.VOB and VTS_02_3.VOB. I get a error:
This is an illegal video file
This is an illegal video file.
For DVD-Video you can only use the following video formats:
MPEG-1 Video, MPEG-2 Video
Its strange because all the files are of the same qualtiy..the only difference i can find is that vts_2 is split into 3 files.
What shd i do to remedy this problem? Thank you for your help and suggestions.
PS; I have download Vobedit after browsing some posts but do not know how to demux the file properly as I still get the same error msg after creating a demxed file.
try click add dvd video and select the vob folder with tmpgenc dvd author. instead of adding the vobs separate.
Thks for your reply. I am now able to add the file. Previously I could not see any tracks with this option as I chose the wrong folder after ripping the DVD with DVDshrink. The files were located in a temp folder but i chose the temp/video_ts folder instead. Will post here again if I am able to create the disc.Originally Posted by Baldrick
IT WORKS!!!!
Thanks again. Hope this helps others with the same problem.
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 01:31 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53 -
New to TMPGEnc DVD Author 3 - Two Questions on Video Quality
By heyjjjaded in forum Authoring (DVD)Replies: 0Last Post: 16th Aug 2007, 13:15 -
I get 2 layers of subs on video in TMPGEnc DVD Author 3...help!
By tektaktyks in forum Video ConversionReplies: 1Last Post: 1st Jul 2007, 12:18
