The topic says it all. Whats a good software that has the template that will let me do this. I have Nero cover designer, but it does not have the templetes that will let me do this....HELP!!
This may not be the answer you're looking for, but for slim DVD covers (I assume you mean the cover insert), I simply use the standard (Meritline)cover insert template in Sure Thing. Then I resize my image horizontally to be about 1/4" short of the right edge of the template. I print to Meritline perforated inserts, but I have to cut the right edge with a scissors or paper cutter because the image doesn't go to the perforation. The other 3 sides are the same as usual.
It's probably not too hard to modify a template but I never thought it worth the trouble to try. I don't think anyone makes a perforated insert sized for slim cases, so no matter what you do with the software, you still have to trim one side.
Does anyone else have a better way?
Need recommended software to edit videos and create a DVD
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 14th Feb 2011, 12:09 -
What software can create AVCHD DVD?
By cheerful in forum Newbie / General discussionsReplies: 9Last Post: 21st Dec 2010, 14:54 -
Create DVD/VHS covers and labels
By MrTemplar in forum Authoring (DVD)Replies: 7Last Post: 21st Oct 2010, 05:53 -
What is your favorite Blu Ray software to create a DVD???
By Endoking01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th Jun 2010, 20:43 -
50 pk slim DVD cases
By zoobie in forum MediaReplies: 0Last Post: 14th Feb 2010, 19:53
